[geos-devel] [GEOS] #753: cannot build geos 3.5.0
GEOS geos-trac at osgeo.org
Mon Jun 19 03:16:49 PDT 2017
 Reporter:  rashadkm               |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  closed
 Priority:  major                  |   Milestone:  3.6.2
Component:  Build/Install (cmake)  |     Version:  3.6.1
 Severity:  Unassigned             |  Resolution:  fixed
 Keywords:                         |
Changes (by mloskot):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 > I'm perhaps missing something here.
 Just do not use CMake to build GEOS, especially if 0) you don't want to
 use experimental build configuration 1) it is not working for you 2) you
 are not able to patch & fix it.
 It is indicated in red that  **The official build system is the GNU
 Automake o**
 https://trac.osgeo.org/geos/wiki/BuildingOnUnixWithCMake
Ticket URL: <https://trac.osgeo.org/geos/ticket/753#comment:17>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
