[geos-devel] [GEOS] #753: cannot build geos 3.5.0
GEOS geos-trac at osgeo.org
Tue Jun 20 05:07:53 PDT 2017
 Reporter:  rashadkm               |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  closed
 Priority:  major                  |   Milestone:  3.6.2
Component:  Build/Install (cmake)  |     Version:  3.6.1
 Severity:  Unassigned             |  Resolution:  fixed
 Keywords:                         |
Comment (by mloskot):
 Replying to [comment:18 rashadkm]:
 > btw, the red text in wiki says official cmake support since 3.5.0.
 The wording on that wiki page is a bit unfortunate as it may suggest that
 in terms of feature and completeness GEOS supports CMake as well as
 Autotools. That is not true.
 CMake is just officially shipped with GEOS, but as far as my info is up to
 date, it is secondary build configuration that may be lacking.
Ticket URL: <https://trac.osgeo.org/geos/ticket/753#comment:20>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
