[geos-devel] Thread safety issues
Tamas Szekeres szekerest at gmail.com
Thu Jun 29 15:00:01 PDT 2017
Thank you, it is sometimes suggested to call the per-thread alternative
uselocale instead of setlocale, for example:
locale_t loc = newlocale(LC_ALL_MASK, "C", NULL);
uselocale(loc);
freelocale(loc)// Do your thing
Or setting the locale on a per stream basis, like:
std::istringstream text( s );
     text.imbue(std::locale::classic());
Not sure if those are applicable in this specific case, however.
Best regards,
Tamas
2017-06-29 23:35 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> On jeudi 29 juin 2017 23:19:30 CEST Tamas Szekeres wrote:
> > Dear developers,
> > We have encountered thread safety issues when invoking the geos C api
> from
> > multiple threads on a site with strong traffic.
> > Specifically CLocalizer is using std::setlocale which is not thread
> safe. (
> > http://en.cppreference.com/w/cpp/locale/setlocale). Do we have a
> workaround
> > to this?
> This strongly reminds me of similar issues we have hit in GDAL and proj.4
> In GDAL, we've now a CPLThreadLocaleC class that use Linux & Windows
> thread-locale specific API to force the C locale when available, and
> otherwise default to a setlocale() call protected by a mutex (which only
> protects 2 concurrent calls to setlocale(), but not a setlocale() with a
> printf())
> See
> https://github.com/OSGeo/gdal/blob/trunk/gdal/port/cpl_conv.cpp#L2785
> https://github.com/OSGeo/gdal/blob/trunk/gdal/port/cpl_conv.cpp#L2843
> But ultimately I ended up rewriting my CPLvsnprintf() to avoid messing up
> with the C locale, and just using vsnprintf() with a later replacing of the
> comma by decimal point (I guess this must be the use case in GEOS too ?) :
> https://github.com/OSGeo/gdal/blob/trunk/gdal/port/cpl_string.cpp#L1119
> And similarly for CPLsscanf() :
> https://github.com/OSGeo/gdal/blob/trunk/gdal/port/cpl_string.cpp#L1430
> Not sure if those are the best way of addressing the issue (I'd wish there
> would be API using always the C-locale), but they are now rather well
> proven.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20170630/2056e07d/attachment-0001.html>
