[geos-devel] [GEOS] #846: UTF8 BOM in headers ?
GEOS geos-trac at osgeo.org
Thu Nov 23 07:00:58 PST 2017
 Reporter:  landry      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.6.3
Component:  Default     |     Version:  3.6.2
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by landry):
 Hmmm well i saw the issue on 3.6 branch, and the fixes are on
 trunk/master, where there's now a requirement for c++1, which will force
 the use of a recent/decent compiler, which will support UTF-8 BOM (as
 that's already the case on amd64/i386 for OpenBSD) - so that should work
 in all cases now, but i cant really test now, unless the commits are
 backported to 3.6.
 Either way, thanks for fixing it!
Ticket URL: <https://trac.osgeo.org/geos/ticket/846#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
