[geos-devel] Segmentation fault when using intersect with multithreading
Tanguy Fardet fardet.tanguy at laposte.net
Thu Nov 23 09:05:56 PST 2017
Hi again,
just to let you know that the segfault dissapears if I store
oneGEOSPreparedGeometry copy of the global GEOSGeom evironment per
OpenMP thread and use the thread-specific copy in GEOSPreparedIntersects_r.
Thus, it seems that, at least in my code and GEOS 3.6.2, the API is not
providing thread safe access to shared data using OpenMP.
Best,
Tanguy
Le 23/11/2017 à 15:50, Sandro Santilli a écrit :
> Are you using the C or C++ API ?
> When using the C API you can define
> the GEOS_USE_ONLY_R_API macro to be
> sure to be only using thread-safe methods.
> If you find a non-reentrant path by using that
> API then please file a bug report including
> the smallest testcase.
> --strk;
