[geos-devel] [postgis-devel] GEOS C++ API deprecated? (was: PostGIS 2.5 what should be minimum requirements?)
Mateusz Loskot mateusz at loskot.net
Sun Oct 1 13:05:43 PDT 2017
On 1 October 2017 at 21:47, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
> On 10/01/2017 09:33 PM, Mateusz Loskot wrote:
>> Unless, Sandro, your aim is to eventually mark C++ API deprecated
>> and stop installing C++ API libraries and headers.
>> That will require RFC and that is what I'm debating about.
> To end this debate once and for all,
Mind you, that does not ends anything, it starts it.
> I'd love for the C++ API to be officially deprecated and no longer installed soon after.
As member of GEOS development team, I'm deeply concerned about
taking such comments seriously, by rest of GEOS team.
> As long as libgeos is provided alongside libgeos_c, C++ projects will be tempted to
> keep using it.
So what.
> And from my perspective as a package maintainer, I would
> like for those projects to stop doing that and have them all use the C
> API instead.
Just stop accepting such GEOS-based software for packaging
and keep nagging authors of such projects to switch to GEOS C API,
but do not delegate your problem to GEOS.
It is not GEOS problem that someone uses GEOS C++ API.
GEOS is C/C++ library.
Having said enough, I'm not going to participate in the debate any longer.
I only ask Sandro, as the GEOS leader/PSC member to answer one question:
Do you plan to practically deprecate GEOS C++ API and stop installing
GEOS C++ headers?
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
