[geos-devel] [postgis-devel] RFC6 - Drop GEOS C++ API at GEOS 3.8
Sebastiaan Couwenberg sebastic at xs4all.nl
Tue Oct 3 10:52:21 PDT 2017
On 10/03/2017 07:37 PM, Howard Butler wrote:
> What if we were to do the same thing with GDAL -- take away GDAL's C++ API which you were not supposed to use, but we put it out there anyway, because it was inconvenient for some of the open source packaging systems? Not possible because too many open source things in Deb/RH use GDAL C++ API, right?
Those projects would be forced to adopt the C API just like for GEOS.
And that would make life for distributions much easier as well,
especially since GDAL has many more reverse dependencies than GEOS.
Because of the importance of GDAL to most projects, they will be
sufficiently motivated to port their project to use the C API.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
