[geos-devel] RFC6 - Discourage use of C++ API by requiring a configure switch to install the c++ headers and SDK
Sebastiaan Couwenberg
sebastic at xs4all.nl
Wed Oct 4 23:02:01 PDT 2017
On 10/05/2017 12:34 AM, Robert Coup wrote:
> Alternative is to work with on C++ APIs/ABIs and compatibility with the
> distros and make it clear that having 7 versions of GEOS installed is
> completely normal. And woe betide if there's a security problem with the
> WKB parser that affects them all. But that's a huge amount of effort to go
> to for something the project has recommended against since forever...
That may be fine for fink, but having more than one version of a library
is not acceptable for Debian and neither is it for EPEL AFAIK. So the
above is not going to happen in the most popular Linux distributions.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
