[geos-devel] git hooks updated to hit Winnie and Debbie web hooks
Regina Obe
lr at pcorp.us
Sat Sep 2 08:09:57 PDT 2017
Strk,
Right now the job names are
For Debbie:
GEOS_Master
GEOS_Branch_3.2
Thru
GEOS_Branch_3.6
For Winnie:
I got to convert the older branches and fix them, but she has
Hers are not that consistent, so I got to rename the branches so you only
got to worry about one set of names.
Assume that Winnie has the same named branches as Debbie and I'll fix.
I'm only going to go as far back as 3.4 for her though cause the others used
auto tools which failed on some tests.
Anyway even if you call a non-existent branch it would just be ignored.
Thanks,
Regina
-----Original Message-----
Sent: Saturday, September 02, 2017 7:51 AM
To: geos-devel at lists.osgeo.org
Cc: Paragon Corporation <lr at pcorp.us>
Subject: git hooks updated to hit Winnie and Debbie web hooks
I've updated the git hooks on the GEOS repository to hit Debbie and Winnie
web hooks upon receiving pushes, but it currently only does so for pushes to
the master branch.
Can we have a clear pattern for mapping branch names to web hook URLs, to
make it more general ? Right now it does:
for branch in ${BRANCHES}; do
if test "${branch}" = "master"; then
curl .../GEOS/jobs/GEOS_Master/....
fi
done
What are the other available job names ?
--strk;
() Free GIS & Flash consultant/developer
/\ https://strk.kbt.io/services.html
