[geos-devel] [GEOS] #841: Regression in prepared polygons contains
geos-trac at osgeo.org
Wed Sep 6 12:09:04 PDT 2017
Reporter: sgillies | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.6.3
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: prepared contains |
Comment (by dbaston):
If I recall (not 100% sure0 there may have been a problem pre-3.5.1 where
the "prepared" implementation of "contains" was never actually called.
That could explain why the prepared/standard results were in agreement,
and are no longer.
Ticket URL: <https://trac.osgeo.org/geos/ticket/841#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
