[geos-devel] [GEOS] #841: Regression in prepared polygons contains
GEOS geos-trac at osgeo.org
Wed Sep 6 13:40:20 PDT 2017
 Reporter:  sgillies           |       Owner:  geos-devel@…
     Type:  defect             |      Status:  closed
 Priority:  major              |   Milestone:  3.6.3
Component:  Default            |     Version:  3.6.2
 Severity:  Unassigned         |  Resolution:  wontfix
 Keywords:  prepared contains  |
Comment (by mdavis):
 Seems like Prepared and Geometry contains should always be in agreement,
 no?  So this seems like something that should be looked into.  In JTS they
 are in agreement (even though the result is not ideal/correct, as per my
 comment above).
Ticket URL: <https://trac.osgeo.org/geos/ticket/841#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
