[geos-devel] Order of results in GEOSDelaunayTriangulation
梁天辰
2284168009 at qq.com
Thu Sep 7 17:54:58 PDT 2017
a possible method to determine a mapping from triangles to nodes:
1.edit geos-3.6.1\src\triangulate\quadedge\QuadEdgeSubdivision.cpp line 588 ,add:
cellPoly->setUserData(reinterpret_cast<void*>(geomFact.createPoint(c)));
return cellPoly;
2.edit geos-3.6.1\src\triangulate\VoronoiDiagramBuilder.cpp line 136 ,moved one line:
else if(clipEnv.intersects(g->getEnvelopeInternal()))
result.reset( clipPoly->intersection(g) );
if(result.get() && !result->isEmpty() )
{result->setUserData(((Geometry*)g)->getUserData()); // moved
clipped->push_back(result.release());
hope this will help.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20170908/161b002a/attachment.html>
