[geos-devel] [GEOS] #867: Regression in union algorithm between GEOS 3.6.1 and GEOS 3.6.2
GEOS geos-trac at osgeo.org
Tue Apr 24 09:48:57 PDT 2018
 Reporter:  robe        |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  blocker     |  Milestone:  3.6.3
Component:  Default     |    Version:  3.6.2
 Severity:  Unassigned  |   Keywords:
 Reported on PostGIS mailing lists
 https://lists.osgeo.org/pipermail/postgis-users/2018-April/042710.html
 Example is exercised in PostGIS, but I concluded the issue is a change
 that happened between GEOS 3.6.1 and 3.6.2
 I'll link to the related PostGIS ticket once it's put in.
Ticket URL: <https://trac.osgeo.org/geos/ticket/867>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
