[geos-devel] [GEOS] #867: Regression in union algorithm between GEOS 3.6.1 and GEOS 3.6.2
geos-trac at osgeo.org
Sat Apr 28 00:48:48 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.6.3
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by bjornharrtell):
Looking into this it seems a likely candidate for this regression is the
work to fix a robustness issue as described by
https://trac.osgeo.org/geos/ticket/837.
Ticket URL: <https://trac.osgeo.org/geos/ticket/867#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
