[geos-devel] [GEOS] #757: IsValid memory exhaustion with degenerate multipolygon
GEOS geos-trac at osgeo.org
Sat Aug 4 21:09:30 PDT 2018
 Reporter:  pramsey     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.5.2
Component:  Default     |     Version:  3.5.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by robe):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 I'm just marking this fixed.  Too many years have gone by to track this
 down.  strk if you feel strongly about it, just add the port notes.
 It doesn't change the fact thought that this issue was fixed a while ago.
Ticket URL: <https://trac.osgeo.org/geos/ticket/757#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
