[geos-devel] [GEOS] #844: Geos 3.6.2 tests failing on ppc64le architecture
geos-trac at osgeo.org
Mon Aug 6 02:57:21 PDT 2018
Reporter: Roberto Oliveira | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.6.4
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by Bas Couwenberg):
3.7.0beta2 has the same test failures and an additional one, see:
https://buildd.debian.org/status/fetch.php?pkg=geos&arch=ppc64el&ver=3.7.0%7Ebeta2-1%7Eexp1&stamp=1533548663&raw=0
Using an overlay tolerance of 2.51369e-05
./tests/ticket/bug350.xml: case1: test2: difference(A, B): failed. (0 ms)
Description: http://trac.osgeo.org/geos/ticket/350 Original data,
fails at noding after snapping
Geometry A: MULTIPOLYGON (((-314775.0000000000000000
2708.0000000000000000, -336712.0000000000000000 -2708.0000000000000000,
-348138.0000000000000000 17051.0000000000000000, -339224.9347079037688673
1637.6219931271461974, -334393.8192419825354591 841.2944606413984729,
-332495.8798798798816279 -1667.0870870870874114, -314775.0000000000000000
2708.0000000000000000)))
Geometry B: MULTIPOLYGON (((-357571.7470252056955360
-5762.1230496452080843, -321742.9143695723614655 -4737.7456185971695959,
-324495.9287155140191317 19374.7701694241804944, -357251.6290780031704344
17838.2040228521254903, -357571.7470252056955360 -5762.1230496452080843)))
Expected result: POLYGON ((-322378.6881546057993546
830.7344192302963393, -322378.6881546057993546 830.7344192302966803,
-314775.0000000000000000 2708.0000000000000000, -322378.6881546057993546
830.7344192302963393))
Obtained result: POLYGON ((-322378.6881546057993546
830.7344192302962256, -322378.6881546057993546 830.7344192302966803,
830.7344192302962256))
Using an overlay tolerance of 3.6e-08
./tests/ticket/bug398.xml: case1: test1: union(A, B): failed. (0 ms)
Description: http://trac.osgeo.org/geos/ticket/398
Assertion `shellCount <= 1' failed.
Geometry A: MULTIPOLYGON (((60.0000000000000000
6.5105151320986412, 44.0044859469790026 11.6931320480208569,
0.0000000000000000 25.9507790663861222, 0.0000000000000000
26.8608278557796467, 0.0000000000000000 29.8387923019253307,
60.0000000000000000 10.3985283676378408, 60.0000000000000000
7.8021345594223774, 60.0000000000000000 6.6570998796460161,
60.0000000000000000 6.5105151320986412)), ((43.3161197496508308
0.0000000000000000, 0.0000000000000000 0.0000000000000000,
0.0000000000000000 14.0346133423735822, 0.0000000000000000
17.9226661292310787, 0.0000000000000000 21.5874865260243638,
34.0258524396557860 6.8981402622972743, 55.3161197496508308
0.0000000000000000, 50.0044466166182886 0.0000000000000000,
43.3161197496508308 0.0000000000000000)), ((13.4455725323347899
36.0000000000000000, 60.0000000000000000 36.0000000000000000,
60.0000000000000000 16.7944518298098018, 60.0000000000000000
16.3644011555093201, 60.0000000000000000 14.0439960304547569,
2.9187843276549756 36.0000000000000000, 11.8945390820010992
36.0000000000000000, 13.4455725323347899 36.0000000000000000)))
Geometry B: POLYGON ((50.0044466166182886 0.0000000000000000,
0.0000000000000000 21.5874865260243638, 0.0000000000000000
35.7392139719321804, 60.0000000000000000 13.1838946818537934,
60.0000000000000000 0.0000000000000000, 50.0044466166182886
Expected result: MULTIPOLYGON (((0.0000000000000000
25.9507790663861222, 0.0000000000000000 26.8608278557796467,
0.0000000000000000 29.8387923019253307, 0.0000000000000000
60.0000000000000000 6.5105151320986412, 60.0000000000000000
0.0000000000000000, 55.3161197496508308 0.0000000000000000,
50.0044466166182886 0.0000000000000000, 43.3161197496508308
0.0000000000000000 25.9507790663861222), (0.0000000000000000
21.5874865260243638, 34.0258524396557860 6.8981402622972743,
34.0258524396557931 6.8981402622972734, 0.0000000000000000
21.5874865260243638)), ((13.4455725323347899 36.0000000000000000,
60.0000000000000000 36.0000000000000000, 60.0000000000000000
16.7944518298098018, 60.0000000000000000 16.3644011555093201,
60.0000000000000000 14.0439960304547569, 2.9187843276549756
36.0000000000000000, 11.8945390820010992 36.0000000000000000,
Obtained result: MULTIPOLYGON (((0.0000000000000000
0.0000000000000000 25.9507790663861222)), ((13.4455725323347899
./tests/general/TestCentroid.xml: case31: test1: getcentroid(A): failed.
(0 ms)
Description: A - almost degenerate triangle
Geometry A: POLYGON ((56.5286666666999977 25.2101666667000011,
56.5290000000000035 25.2104999999999997, 56.5288333332999997
25.2103333332999995, 56.5286666666999977 25.2101666667000011))
Expected result: POINT (56.5288333333500006 25.2103333333500004)
Obtained result: POINT (56.5288333333333313 25.2103333333333346)
Ticket URL: <https://trac.osgeo.org/geos/ticket/844#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
