[geos-devel] [GEOS] #809: Test failure with MinimumClearanceLine with geos 3.6.1
GEOS geos-trac at osgeo.org
Mon Aug 6 14:55:52 PDT 2018
 Reporter:  goatbar               |       Owner:  geos-devel@…
     Type:  defect                |      Status:  closed
 Priority:  major                 |   Milestone:  3.6.3
Component:  Default               |     Version:  3.6.0
 Severity:  Unassigned            |  Resolution:  worksforme
 Keywords:  MinimumClearanceLine  |
Changes (by robe):
 * milestone:  3.6.4 => 3.6.3
Comment:
 Switching back to 3.6.3 as I presume it was fixed then.  Feel free to
 switch to 3.7.0 or 3.6.4 if that is incorrect.
Ticket URL: <https://trac.osgeo.org/geos/ticket/809#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
