[geos-devel] [GEOS] #864: GEOSNode throws std::exception in PostGIS
GEOS geos-trac at osgeo.org
Tue Aug 7 18:36:00 PDT 2018
 Reporter:  komzpa      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.6.4
Component:  Default     |     Version:  3.6.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Changes (by dbaston):
 * Attachment "864-test.patch" added.
 failing tests case
Ticket URL: <https://trac.osgeo.org/geos/ticket/864>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
