[geos-devel] [GEOS] #914: cmake compile under mingw64 gcc 8.1
GEOS geos-trac at osgeo.org
Sun Aug 19 05:00:32 PDT 2018
 Reporter:  robe                   |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  closed
 Priority:  major                  |   Milestone:  3.8.0
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Significant            |  Resolution:  fixed
 Keywords:  mingw64 gcc 8.1        |
Changes (by Regina Obe <lr@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"9ed254c129428b12228fcb9e09f9bd87cf0f3b29/git" 9ed254c/git]:
 #!CommitTicketReference repository="git"
 revision="9ed254c129428b12228fcb9e09f9bd87cf0f3b29"
 Apply Vicky's remove unnecessary cmake stuff no longer needed for c+11
 Closes #914 for GEOS 3.8
Ticket URL: <https://trac.osgeo.org/geos/ticket/914#comment:14>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
