[geos-devel] GEOS 3.7.0rc1 release
Greg Troxel
gdt at lexort.com
Tue Aug 21 06:26:42 PDT 2018
Sebastiaan Couwenberg <sebastic at xs4all.nl> writes:
> On 8/21/18 1:25 AM, Greg Troxel wrote:
>> is malformed. It's the .* production that the ? applies to (present or
>> not).
>> VERSION_RELEASE=`echo "$VERSION" | sed -E 's/^([0-9]+\.[0-9]+\.[0-9]+)(.*)?$/\1/'`
>> GNU sed may be allowing this as an extension, because "*?" doesn't make
>> sense, since * is repetition.
> Note the -E option for extended regular expressions which came from GNU
> sed but is now included in POSIX.
> The ? should make the .* expression non-greedy.
Sorry, I am not following. I dug into this harder than probably makes
sense because I wanted to make sure there wasn't a bug in NetBSD's sed,
in which case I would file a bug report so it is fixed.
I don't see -E in POSIX's sed spec:
http://pubs.opengroup.org/onlinepubs/9699919799/utilities/sed.html
However, NetBSD's sed (and I suspect basically all others) does document
-E for extended regular expressions.
But, in the posix spec for extended regular expressions:
http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/V1_chap09.html
I don't see that .*? is legal, opposed to (.*)?
Specifically, in 9.4.6.4, it says
The behavior of multiple adjacent duplication symbols ( '+', '*', '?',
and intervals) produces undefined results.
and it looks like this ? modifier is a perl regex thing:
https://stackoverflow.com/questions/1103149/non-greedy-reluctant-regex-matching-in-sed
But I don't understand why this is hard in this particular, case, since
we're trying to take things like
1.2.3
3.4.5rc3
and produce
1.2.3
3.4.5
and I would think the point is to have the .* eat up everything after
the third number.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20180821/b2fec655/attachment.sig>
