[geos-devel] [GEOS] #894: FreeBSD failures on 3.7.0 - group: geos::geom::CoordinateArraySequenceFactory, test: test<1> assertion failed
GEOS geos-trac at osgeo.org
Mon Aug 27 13:23:44 PDT 2018
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.7.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by robe):
 Had Greg Troxel check this and he says it is failing on his MacOSX, but
 works fine on NetBASD.  Both FreeBSD and MacOSX use clang, while NetBSD
 uses gcc
 same error on macos 10.11, with
 Apple LLVM version 8.0.0 (clang-800.0.42.1)
 Target: x86_64-apple-darwin15.6.0
 Thread model: posix
 InstalledDir: /Library/Developer/CommandLineTools/usr/bin
 so the finger is pointing at clang being what makes the difference.
 (But not at clang, because it's much more likely there is some dodgy code
 that triggers with clang, than that clang is buggy, IMHO.)
Ticket URL: <https://trac.osgeo.org/geos/ticket/894#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
