[geos-devel] Refactoring CoordinateSequence
    Daniel Baston
    dbaston at gmail.com
    Thu Aug 30 08:19:45 PDT 2018
Hi Regina,
This work would be not cause any changes to the C API, though we would
ultimately want to add some functions to the C API to create packed
coordinate sequences.
Dan
On Thu, Aug 30, 2018 at 9:53 AM Regina Obe <lr at pcorp.us> wrote:
> I have no objection.  I know Vicky was complaining about the large number
> of functions that should be private that are exposed. She was planning to
> deprecate them in 3.8 and remove/make private in a later release.
> I'm not sure if this is related to that if she's even looked at that
> class.  Are these linked into CAPI at all?  If so we should probably stub
> them with an error, if not, I don't care if they are removed as we never
> said the C++ -API is stable yet.  My hope is once we clean things up a bit,
> we can guarantee some level of stability for the C++ API as well.
> Thanks,
> Regina
> *From:* geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] *On Behalf
> Of *Daniel Baston
> *Sent:* Thursday, August 30, 2018 9:10 AM
> *To:* GEOS Development List <geos-devel at lists.osgeo.org>
> *Subject:* [geos-devel] Refactoring CoordinateSequence
> I've been exploring porting the PackedCoordinateSequence from JTS to GEOS
> because it seems like a useful way to improve the interoperability of GEOS
> with other code (LWGEOM, for example) without requiring copying of
> everything into GEOS data structures. It turns out that extending
> CoordinateSequence is pretty onerous in GEOS; the CoordinateSequence class
> contains many abstract methods that are not in the corresponding
> CoordinateSequence JTS interface. These methods add requirements of
> mutability (CoordinateSequence::setAt) and extensibility/contractability
> (CoordianteSequence::add, CoordianteSequence::deleteAt) and require the
> author of a derived class to implement functionality that could be seen as
> unrelated to storing a sequence of coordinates (removeRepeatedPoints,
> apply_ro, etc.). Does anyone know why so many methods are added to GEOS
> CoordinateSequence that have no JTS equivalent, and are there any
> objections to factoring some of the functionality out of the
> CoordianteSequence class so that it's easier to write other
> CoordinateSequence implementations?
> Dan
> geos-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20180830/2bba9413/attachment.html>
