[geos-devel] [GEOS] #849: clang-tidy: readability-container-size-empty size() == 0 can be replaced with empty()
GEOS geos-trac at osgeo.org
Thu Aug 30 18:40:54 PDT 2018
with empty()
 Reporter:  goatbar                              |       Owner:  geos-
                                                 |  devel@…
     Type:  defect                               |      Status:  closed
 Priority:  minor                                |   Milestone:  3.8.0
Component:  Default                              |     Version:  master
 Severity:  Unassigned                           |  Resolution:  fixed
 Keywords:  clangtidy size empty readability-    |
  container-size-empty                           |
Changes (by cvvergara <vicky@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"55d8d35b2a399deb324239573881d947fca49061/git" 55d8d35/git]:
 #!CommitTicketReference repository="git"
 revision="55d8d35b2a399deb324239573881d947fca49061"
 Closes #849, Using empty() instead of comparing size() vs 0
Ticket URL: <https://trac.osgeo.org/geos/ticket/849#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
