[geos-devel] C++14
Daniel Baston dbaston at gmail.com
Thu Dec 13 08:55:36 PST 2018
Paul raised an issue yesterday about how to mark something as "deprecated"
without using the "[[deprecated]]" attribute provided in C++14.
It made me wonder what others think about using C++14 for GEOS. I see C++14
as mostly a "bugfix" to C++11, introducing things like std::make_unique
that were oddly omitted from C+11.
If we are going to modernize the code to use C++11, why not go straight to
C++14? Are there major platforms that support C++11 but not C++14?
If you look at this chart, there is no release of gcc, clang, or MSVC that
supports ALL of C++11 without also supporting ALL of C++14:
https://en.cppreference.com/w/cpp/compiler_support
In all cases, you need gcc5, clang 3.8, or MSVC 19.0. (But yes, _most_ of
C++11 is implemented in earlier releases of these.)
What do others think? One argument I can think of against this is that it
complicates backporting of bugfixes.
Dan
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20181213/3f777693/attachment.html>
