[geos-devel] C++14
Nyall Dawson nyall.dawson at gmail.com
Sun Dec 16 15:17:30 PST 2018
On Mon, 17 Dec 2018 at 04:08, Vicky Vergara <vicky at georepublic.de> wrote:
> More or less:
> C++14 adds to C++11:
> Relaxed constexpr constraints
> Generic lambdas (e.g., [](auto p) { return p*2; })
> Init-capture (e.g., [i = 2](auto p) { return p+i++; })
> Variable templates
> decltype(auto)
> Deduced return types
> Binary literals (e.g., 0b11101100)
> Digit separators (e.g., 0b1110'1100)
> Extend “aggregate class type” to include a class that would be a C++11 aggregate type if default member initializers were omitted
> [[deprecated]] and [[deprecated("msg")]]
There's also the very useful make_unique function.
But it's possible to "backport" make_unique to c++11, which is what we
do in QGIS: https://github.com/qgis/QGIS/blob/master/src/core/qgis.h#L357
Nyall
> So the question is:
> How much GEOS need those new features?
> Its not using a lot of features of C++11 anyway
> with c++ you can still use unique_ptr
> I have a lot of (stalled) work in this branch
> https://github.com/cvvergara/geos/tree/gPolygonizer
> where the intention is to use more the unique_ptr and/or shared pointer
> For example:
> https://github.com/cvvergara/geos/commit/f6c12cf17a40ddbe3b7e88b63728aac104ab8efa
> C++11 I think is good enough
> On Thu, Dec 13, 2018 at 6:31 PM Kurt Schwehr <schwehr at gmail.com> wrote:
>> Getting people to be willing to drop support for old compilers is really difficult.  Especially without people who can provide strong support for older branches of all the related code bases.  A bunch of discussion went into the topic for these 2 RFCs...
>> https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11
>> https://trac.osgeo.org/geos/wiki/RFC5
>> C++14 isn't that huge of a jump and if there are features that people really want that are available in libs like abseil, it isn't unreasonable to port a copy into a private namespace of GEOS and use it until it can be refactored out when the minimum compiler make the standin irrelevant.  e.g. make_unique is here and could be converted to geos::private::make_unique or some such.
>> https://github.com/abseil/abseil-cpp/blob/master/absl/memory/memory.h
>> For deprecated, can just start with something simple like ABSL_DEPRECATED.  And drop it when you can.
>> https://github.com/abseil/abseil-cpp/blob/master/absl/base/macros.h#L134
>> On Thu, Dec 13, 2018 at 11:34 AM Greg Troxel <gdt at lexort.com> wrote:
>>> "Regina Obe" <lr at pcorp.us> writes:
>>> > I think a lot of packaging (for older systems I see) I see is still
>>> > done on gcc 4.7.  Though one can argue that these older systems will
>>> > not ship newer GEOS, so might not be so much of an issue aside from
>>> > users who build their own GEOS stuck on old platforms.
>>> A good point for Linux, but in the non-Linux world (BSD, MacOS, Solaris, and
>>> the rest of the vendor unix tradition) there is usually a notion of
>>> "base system" and "packages or other stuff".  So with have things like
>>> mv and the compiler in base, and then packages, the idea of wanting to
>>> build newer packages with a not bleeding edge but not ancient compiler
>>> (which describes gcc 4.8) is not really that strange.
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geos-devel
>> http://schwehr.org
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
