[geos-devel] [GEOS] #948: regression timed out mingw64 gcc 8.1
    geos-trac at osgeo.org
    Fri Dec 21 12:12:17 PST 2018
 Reporter:  robe        |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.8.0
Component:  Default     |    Version:  master
 Severity:  Unassigned  |   Keywords:
 It's been a while since I tried to compile and make check geos on master.
 I tried against master and got this output:
 [100%] Linking C executable ../../../bin/perf_memleak_mp_prep.exe
 [100%] Built target perf_memleak_mp_prep
 UpdateCTestConfiguration  from
 :C:/ming64gcc81/projects/geos/branches/build/DartConfiguration.tcl
 Test project C:/ming64gcc81/projects/geos/branches/build
 Constructing a list of tests
 Done constructing a list of tests
 Updating test list for fixtures
 Added 0 tests to meet fixture requirements
 Checking test dependency graph...
 Checking test dependency graph end
 test 1
     Start 1: test_geos_unit
 1: Test command:
 C:\ming64gcc81\projects\geos\branches\build\bin\test_geos_unit.exe
 1: Test timeout computed to be: 10000000
 1: ===============================
 1:   GEOS Test Suite Application
 1:
 This is first I've ever seen of a timeout?  Anyone else getting this
Ticket URL: <https://trac.osgeo.org/geos/ticket/948>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
