[geos-devel] [GEOS] #924: geometries returned by getGeometryN() should have the same SRID as collection
geos-trac at osgeo.org
Thu Dec 27 17:02:30 PST 2018
collection
Reporter: sirsigurd | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by dbaston):
The proposed behavior (components have same SRID as collection) is
consistent w/JTS:
-> GeometryFactory gf = new GeometryFactory(new PrecisionModel(), 4326);
| Added variable gf of type GeometryFactory with initial value
org.locationtech.jts.geom.GeometryFactory at 21213b92
-> WKTReader reader = new WKTReader(gf);
| Added variable reader of type WKTReader with initial value
org.locationtech.jts.io.WKTReader at 3327bd23
-> Geometry g = reader.read("GEOMETRYCOLLECTION(POINT (3 7), LINESTRING (0
0, 1 1))");
| Added variable g of type Geometry with initial value GEOMETRYCOLLECTION
(POINT (3 7), LINESTRING (0 0, 1 1))
-> g.getSRID();
| Expression value is: 4326
| assigned to temporary variable $12 of type int
-> g.getGeometryN(0).getSRID();
| assigned to temporary variable $13 of type int
-> g.getGeometryN(1).getSRID();
| assigned to temporary variable $14 of type int
Ticket URL: <https://trac.osgeo.org/geos/ticket/924#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
