[geos-devel] dynamic_cast may yield null pointers in AbstractSTRtree::query and AbstractSTRtree::itemsTree on OS X
Kurt Schwehr
schwehr at gmail.com
Thu Jan 4 11:22:32 PST 2018
Ouch :(
Some thoughts... you might be getting different versions of the library
(e.g. different compiler versions or flags for the same version of
libgeos). otool -L and dtrace are places to start, but aren't fun. Is it
happening on multiple machines? Using macports, fink, homebrew, or for the
libs?
On Wed, Jan 3, 2018 at 10:34 AM, Sean Gillies <sean.gillies at gmail.com>
wrote:
> Hi and Happy New Year, all.
> I found time recently to make notes on a frustrating issue that I'm having
> with GEOS in the Shapely binary wheels for OS X that I'm publishing on
> PyPI. I'm not certain whether there's a GEOS bug, a dynamic loader bug, a
> ctypes bug, misuse of computers on my part, or all four. I'd really
> appreciate a bit of advice from anyone with more C++ and Mach-O wisdom that
> would rule out a few of these possibilities.
> Here's the gist of it: Shapely uses dlopen (via Python's ctypes) to load
> libgeos_c.dylib at run time. The GEOS C++ library (libgeos-3.6.2.dylib, for
> example) is a dependent library of libgeos_c.dylib. I have been
> distributing the GEOS libs with my Shapely binaries for convenience of
> users, but Shapely also works with GEOS installed to the standard places on
> your system. I've never experienced or seen report of a problem with
> Shapely's loading of the GEOS libraries *in isolation* that hasn't been
> fixed.
> My Fiona package for Python also depends on libgeos_c.dylib, but in the
> more familiar way: it's a dependent library of GDAL, which is loaded when
> Fiona's C extension modules are loaded in Python.
> If we import fiona in a Python script and then import shapely from a
> binary wheel that includes GEOS libraries, the script will abort in either
> AbstractSTRtree::query or AbstractSTRtree::itemsTree because the dynamic
> casts yield null pointers. As far as I can tell, loading two copies of the
> C++ GEOS library is where the trouble starts. Is the trouble in the loader,
> the library code, or my builds? I do not know.
> There's no problem on Linux. The Linux library loader may be more
> foolproof or the library code might be compiled more correctly in a way
> that I don't yet see. I'm using the following flags in my builds – the dual
> architecture build is the only thing that seems unusual to me.
> environment =
> MACOSX_DEPLOYMENT_TARGET=10.9
> configure-options =
> CFLAGS="-arch i386 -arch x86_64 -O2 -Wl,-S -Wall -Wstrict-prototypes"
> CXXFLAGS="-arch i386 -arch x86_64 -O2 -Wl,-S -Wall -Wstrict-prototypes"
> LDFLAGS="-arch i386 -arch x86_64"
> The thing that makes me suspect that there is a localized bug in GEOS is
> that loading the library twice doesn't lead to failures in computing areas,
> lengths, predicates, or WKT serializations. Only in the AbstractSTRtree
> module as far as I can tell.
> I've made a ticket at https://trac.osgeo.org/geos/ticket/848 and have
> attached a script that reproduces the problem as well as demonstrating that
> other GEOS modules are unaffected.
> It's interesting, but mostly baffling and humbling to go so deep into the
> weeds of dynamic library loading. I'm over my head here and super grateful
> for insights and discussion.
> Sean Gillies
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20180104/66efad6b/attachment.html>
