[geos-devel] [GEOS] #849: clang-tidy: readability-container-size-empty site() == 0 can be replaced with empty()
GEOS geos-trac at osgeo.org
Fri Jan 5 10:22:31 PST 2018
with empty()
 Reporter:  goatbar      |      Owner:  geos-devel@…
     Type:  defect       |     Status:  new
 Priority:  minor        |  Milestone:  3.6.3
Component:  Default      |    Version:  master
 Severity:  Unassigned   |   Keywords:  clangtidy size empty readability-
 https://clang.llvm.org/extra/clang-tidy/checks/readability-container-size-
 empty.html
 There are at least 9 of these
 e.g.
 {{{#!c++
 std::size_t
 CoordinateArraySequence::getDimension() const
     if( dimension != 0 )
         return dimension;
     if( vect->size() == 0 )
         return 3;
     if( ISNAN((*vect)[0].z) )
         dimension = 2;
     else
         dimension = 3;
     return dimension;
 Could be
 {{{#!c++
 std::size_t
         return dimension;
     if( vect->empty() )  // <<-- fix here
         return 3;
         dimension = 2;
     else
         dimension = 3;
     return dimension;
Ticket URL: <https://trac.osgeo.org/geos/ticket/849>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
