[geos-devel] PSC Vote Add Vicky Vergara as GEOS committer
Vicky Vergara
vicky at georepublic.de
Sun Jul 22 14:13:27 PDT 2018
Hello all
I have read the RFC2 carefully, which still talks about svn but I imagine
the same stuff applies to gitea or whatever comes out in the far future.
(not that I will be pushing directly to the geos project)
I feel honored to be a committer, (and Daniel is giving me the thumbs up),
of course I accept.
As Regina mentioned, I have plans, and this week end I started "playing"
with geos.
play = have fun experimenting with code improvements (and learn what its
doing internally)
I wanted to start with changing the for loops to range loops, and chose
PolygonizeGraph class as first C++ class where to do the changes.
but when I started doing that small change, I just couldn't stop myself
from using c++11 goodies on PolygonizeGraph.
Now the file does not look at all as the original (big smile)
java is not C++, so C++ does not need to look like java, now, in my
opinion, the code on PolygonizeGraph looks more like C++.
https://github.com/libgeos/geos/compare/master...cvvergara:PolygonizeGraph
If you are curious, follow the sequence of commits to see more or less how
I work, because at the end all will be squashed, and no squashed does not
show the way I think when moving from one commit to the next.
also because at the end all commits are going to be squashed, I don't care
if the commit message makes sense or not.
I wish I could say that I am done with that class, but unfortunately its a
derived class, so when tackling the base class, this one will have changes.
I will try to work one class per weekend, (header and code + consequences)
see you on the chat :)
Vicky
On Fri, Jul 20, 2018 at 9:23 AM, Regina Obe <lr at pcorp.us> wrote:
> Vicky,
> Looks like we have enough votes to pass this motion and non -1s.
> Before we give you commit access, can you read the below and confirm you
> agree with all.
> https://trac.osgeo.org/geos/wiki/RFC2
> Thanks,
> Regina
> *From:* geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] *On Behalf
> Of *Dale Lutz
> *Sent:* Thursday, July 19, 2018 8:00 PM
> *To:* GEOS Development List <geos-devel at lists.osgeo.org>
> *Subject:* Re: [geos-devel] PSC Vote Add Vicky Vergara as GEOS committer
> +1
> On Wed, Jul 18, 2018 at 4:12 PM, Regina Obe <lr at pcorp.us> wrote:
> > Vicky has been doing work modernizing GEOS code to follow newer C++
> > standards.
> > She plans to do more of this when we flip the switch to GEOS 3.8.0.
> > To make it easier, I'd like to add her as a committer to GEOS project.
> > All PSC folks, please vote and express any concerns.
> > +1 from me
> > Thanks,
> > Regina
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20180722/5563e40f/attachment.html>
