[geos-devel] [GEOS] #865: GEOSClipByRect failure
GEOS geos-trac at osgeo.org
Fri Jul 27 12:45:11 PDT 2018
 Reporter:  komzpa      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  reopened
 Priority:  major       |   Milestone:  3.6.3
Component:  Default     |     Version:  3.6.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by dbaston):
 Thanks for the detailed report. It looks easy enough to throw an exception
 in this case, which would be a big improvement over an infinite loop.
Ticket URL: <https://trac.osgeo.org/geos/ticket/865#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
