[geos-devel] [GEOS] #881: gitlab ci is broken
geos-trac at osgeo.org
Mon Jun 11 09:39:51 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.6.3
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by robe):
I think it's something wrong with geos config on gitlab, because if I use
the PostGIS CI Link -
https://gitlab.com/postgis/postgis/-/ci/lint
to validate geos yaml script it's fine. But any yaml script I feed geos
results in a 500
https://gitlab.com/geos/libgeos/-/ci/lint
Ticket URL: <https://trac.osgeo.org/geos/ticket/881#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
