[geos-devel] [GEOS] #888: Fix check-local failure when quilt patches are applied
geos-trac at osgeo.org
Thu Jun 14 05:15:05 PDT 2018
Reporter: Bas Couwenberg | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Default | Version: 3.6.2
Severity: Unassigned | Keywords:
The `check-local` target failed because it has the spelling error quilt
patch applied:
make check-local
make[5]: Entering directory '/build/geos-3.7.0~alpha'
! find . -name '*.cpp' -o -name '*.h' | \
grep -v ^./tests/xmltester/tinyxml | \
xargs grep -n '[[:space:]]$'
./.pc/spelling-errors.patch/tests/xmltester/tinyxml/tinyxml.h:83:#endif
./.pc/spelling-errors.patch/tests/xmltester/tinyxml/tinyxml.h:98:/*
Internal structure for tracking location of items
./.pc/spelling-errors.patch/tests/xmltester/tinyxml/tinyxml.h:1764:
/** Switch over to "stream printing" which is the most dense formatting
without
./.pc/spelling-errors.patch/tests/xmltester/tinyxml/tinyxml.h:1769:
make[5]: *** [Makefile:931: check-local] Error 1
make[5]: Leaving directory '/build/geos-3.7.0~alpha'
The attached patch fixes the issue by using a less strict pattern to
exclude.
Ticket URL: <https://trac.osgeo.org/geos/ticket/888>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
