[geos-devel] [GEOS] #887: Remove pre-release suffix from library name (libgeos-3.7.0alpha.so -> libgeos-3.7.0.so)
geos-trac at osgeo.org
Thu Jun 14 06:08:32 PDT 2018
libgeos-3.7.0.so)
Reporter: Bas Couwenberg | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.7.0
Component: Default | Version: master
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by Sandro Santilli <strk@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"5eca48f4097054d0b2218ab2f6b7d817b6a9b0d6/git" 5eca48f/git]:
#!CommitTicketReference repository="git"
revision="5eca48f4097054d0b2218ab2f6b7d817b6a9b0d6"
Strip pre-release suffix from library name
Patch by Bas Couwenberg
Closes #887
Ticket URL: <https://trac.osgeo.org/geos/ticket/887#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
