[geos-devel] [GEOS] #742: Various patches from the geos Debian package
geos-trac at osgeo.org
Thu Jun 14 06:25:02 PDT 2018
Reporter: Bas Couwenberg | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Default | Version: 3.5.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by Bas Couwenberg):
The symlink is present:
$ dpkg-deb -c ../libgeos++-dev_3.7.0~alpha-1~exp1_amd64.deb | grep usr/lib
| grep libgeos
-rw-r--r-- root/root 5366122 2018-06-14 09:17 ./usr/lib/x86_64-linux-
gnu/libgeos.a
lrwxrwxrwx root/root 0 2018-06-14 09:17 ./usr/lib/x86_64-linux-
gnu/libgeos.so -> libgeos-3.7.0.so
So the `geos-config` patch could be dropped, although I also prefer
explicitly including the versioned library name as that matches the
SONAME. Note that Francesco Paolo Lovergine originally developed that
patch which also included adding the {{clibs}} option, see:
https://salsa.debian.org/debian-gis-
team/geos/commit/216878271f27a5662920f7f23e710da46957f4a3
Ticket URL: <https://trac.osgeo.org/geos/ticket/742#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
