[geos-devel] [GEOS] #887: Remove pre-release suffix from library name (libgeos-3.7.0alpha.so -> libgeos-3.7.0.so)
GEOS geos-trac at osgeo.org
Thu Jun 14 22:55:56 PDT 2018
libgeos-3.7.0.so)
 Reporter:  Bas Couwenberg  |       Owner:  geos-devel@…
     Type:  defect          |      Status:  closed
 Priority:  major           |   Milestone:  3.7.0
Component:  Default         |     Version:  master
 Severity:  Unassigned      |  Resolution:  fixed
 Keywords:                  |
Changes (by Regina Obe <lr@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"40314bb47e7f5025675ec833c8a8fa11c3ce313b/git" 40314bb/git]:
 #!CommitTicketReference repository="git"
 revision="40314bb47e7f5025675ec833c8a8fa11c3ce313b"
 Revise remove pre-release suffix to handle lack of number, and presense of
 dev. Closes #887
Ticket URL: <https://trac.osgeo.org/geos/ticket/887#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
