[geos-devel] [GEOS] #591: Port robust determinant fixes from JTS
GEOS geos-trac at osgeo.org
Sun Jun 17 00:36:19 PDT 2018
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.7.0
Component:  Default     |     Version:  3.3.5
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by robe):
 Are there any plans to do this or should I just push to the fundme
 category.
 I'm also unclear if this is partly done or completely done since the
 https://github.com/libgeos/libgeos/pull/40
 is closed
Ticket URL: <https://trac.osgeo.org/geos/ticket/591#comment:15>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
