[geos-devel] [GEOS] #894: FreeBSD failures on 3.7.0
    geos-trac at osgeo.org
    Wed Jun 27 05:22:15 PDT 2018
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.7.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by robe):
 aha found the log.  Not sure how I missed it before here is the bessie32
 bit one:
    : tests/unit/test-suite.log
 # TOTAL: 1
 # PASS:  0
 # SKIP:  0
 # XFAIL: 0
 # FAIL:  1
 # XPASS: 0
 # ERROR: 0
 .. contents:: :depth: 2
 FAIL: geos_unit
   GEOS Test Suite Application
 capi::GEOSBuffer: ....................
 capi::GEOSClipByRect: .............
 capi::GEOSContains: .....
 capi::GEOSConvexHull: .
 capi::GEOSCoordSeq: ........NOTICE: IllegalArgumentException: Ring has
 fewer than 3 points, so orientation cannot be determined
 capi::GEOSDelaunayTriangulation: ......
 capi::GEOSDistance: ..
 capi::GEOSEquals: ...NOTICE: IllegalArgumentException: RobustDeterminant
 encountered non-finite numbers
 .NOTICE: IllegalArgumentException: RobustDeterminant encountered non-
 finite numbers
 capi::GEOSFrechetDistance: ..
 capi::GEOSGeomFromWKB: .....
 capi::GEOSGeomToWKT: .............
 capi::GEOSGeom_create: .......
 capi::GEOSGeom_extractUniquePoints: ...
 capi::GEOSGeom_getXYMinMax: ..
 capi::GEOSGeom_setPrecision: .....
 capi::GEOSGetCentroid: .....
 capi::GEOSHausdorffDistance: ..
 capi::GEOSInterrupt: ...NOTICE: InterruptedException: Interrupted!
 capi::GEOSIntersection: ....
 capi::GEOSIntersects: ...NOTICE: IllegalArgumentException:
 RobustDeterminant encountered non-finite numbers
 finite numbers
 capi::GEOSLineStringPoint: ....
 capi::GEOSMinimumClearance: .....
 capi::GEOSMinimumRotatedRectangle: .
 capi::GEOSMinimumWidth: ..
 capi::GEOSNearestPoints: ..
 capi::GEOSNode: ...
 capi::GEOSOffsetCurve: .........NOTICE: IllegalArgumentException: Cannot
 get offset of single-vertex line
 capi::GEOSOrientationIndex: ...........
 capi::GEOSPointOnSurface: .........
 capi::GEOSPolygonizeGetCutEdges: ..
 capi::GEOSPreparedGeometry: ...........
 capi::GEOSRelateBoundaryNodeRule: .......NOTICE: Invalid boundary node
 rule 5
 capi::GEOSRelatePatternMatch: .....
 capi::GEOSReverse: ........
 capi::GEOSSTRtree: ..NOTICE: Can't compute envelope of item in
 BoundablePair
 ..NOTICE: Can't compute envelope of item in BoundablePair
 ..NOTICE: IllegalArgumentException: Geometry is not lineal
 capi::GEOSSharedPaths: ..NOTICE: IllegalArgumentException: Geometry is not
 lineal
 capi::GEOSSimplify: .
 capi::GEOSSnap: ..........
 capi::GEOSUnaryUnion: ........NOTICE: IllegalArgumentException: EdgeEnd
 with coordinate nan nan invalid for node nan nan
 capi::GEOSUserData: ..
 capi::GEOSVoronoiDiagram: ......
 capi::GEOSWithin: ...
 capi::GEOSisClosed: ....
 capi::GEOSisValidDetail: ......
 capi::defines: ..
 geos::algorithm::Angle: ....
 geos::algorithm::CGAlgorithms::computeOrientation: ..
 geos::algorithm::CGAlgorithms::isCCW: .....
 geos::algorithm::CGAlgorithms::isPointInRing: ..
 geos::algorithm::CGAlgorithms::signedArea: ...
 geos::algorithm::ConvexHull: .......
 geos::algorithm::InteriorPointArea: .
 geos::algorithm::MinimumDiameter: ..........
 geos::algorithm::PointLocator: .....
 geos::algorithm::RobustLineIntersection: ......
 geos::algorithm::RobustLineIntersector: ...............
 geos::algorithm::distace::DiscreteFrechetDistance: ....
 geos::algorithm::distace::DiscreteHausdorffDistance: ....
 geos::geom::Coordinate: .........
 geos::geom::CoordinateArraySequence: .................
 geos::geom::CoordinateArraySequenceFactory: [1=F]....
 geos::geom::CoordinateList: ...
 geos::geom::Dimension: .....
 geos::geom::Envelope: .........
 geos::geom::Geometry::clone: .......
 geos::geom::Geometry::covers: ....
 geos::geom::Geometry::equals: .
 geos::geom::Geometry::isRectangle: .......
 geos::geom::Geometry::normalize: .......
 geos::geom::GeometryFactory: ....................................
 geos::geom::IntersectionMatrix: .............................
 geos::geom::LineSegment: ......
 geos::geom::LineString: .........................
 geos::geom::LinearRing: ..............................
 geos::geom::Location: ...
 geos::geom::MultiLineString: .
 geos::geom::MultiPoint: ............................
 geos::geom::MultiPolygon: .
 geos::geom::Point: ........................................
 geos::geom::Polygon: ......................................
 geos::geom::PrecisionModel: .........
 geos::geom::Triangle: ......
 geos::geom::prep::PreparedGeometryFactory: .............................
 geos::geom::util::GeometryExtracter: ..
 geos::index::quadtree::DoubleBits: .
 geos::io::ByteOrderValues: ...
 geos::io::WKBReader: .........
 geos::io::WKBWriter: .....
 geos::io::WKTReader: ........
 geos::io::WKTWriter: .....
 geos::io::Writer: ....
 geos::linearref::LocationIndexedLine: ...........................
 geos::noding::BasicSegmentString: ....
 geos::noding::NodedSegmentString: .....
 geos::noding::OrientedCoordinateArray: .....
 geos::noding::SegmentNode: ....
 geos::noding::SegmentPointComparator: .....
 geos::noding::snapround::HotPixel: ...
 geos::noding::snapround::MCIndexSnapRounder: .
 geos::operation::IsSimpleOp: ...
 geos::operation::OverlayOp::UNION: .
 geos::operation::buffer::BufferBuilder: .
 geos::operation::buffer::BufferOp: ...........
 geos::operation::buffer::BufferParameters: ..........
 geos::operation::distance::DistanceOp: ...................
 geos::operation::geounion::CascadedPolygonUnion: .
 geos::operation::geounion::UnaryUnionOp: ......
 geos::operation::intersection::RectangleIntersection:
 geos::operation::linemerge::LineMerger: ........
 geos::operation::linemerge::LineSequencer: ............
 geos::operation::overlay::snap::GeometrySnapper: ..
 geos::operation::overlay::snap::LineStringSnapper: .........
 geos::operation::overlay::validate::FuzzyPointLocator: .......
 geos::operation::overlay::validate::OffsetPointGenerator: .....
 geos::operation::overlay::validate::OverlayResultValidator: ......
 geos::operation::polygonize::Polygonizer: ..
 geos::operation::sharedpaths::SharedPathsOp: .....................
 geos::operation::valid::IsValidOp: .
 geos::operation::valid::ValidClosedRing: .....
 geos::operation::valid::ValidSelfTouchingRingFormingHole: .......
 geos::precision::GeometryPrecisionReducer: .........
 geos::precision::SimpleGeometryPrecisionReducer: .......
 geos::simplify::DouglasPeuckerSimplifier: ............
 geos::simplify::TopologyPreservingSimplifier: ...............
 geos::triangulate::Delaunay: .........
 geos::triangulate::Voronoi: .........
 geos::triangulate::quadedge::QuadEdge: ...
 geos::triangulate::quadedge::QuadEdgeSubdivision: ...
 geos::triangulate::quadedge::Vertex: .
 geos::util::UniqueCoordinateArrayFilter: .
 ---> group: geos::geom::CoordinateArraySequenceFactory, test: test<1>
      problem: assertion failed
 tests summary: failures:1 ok:1117
 FAIL geos_unit (exit status: 1)
Ticket URL: <https://trac.osgeo.org/geos/ticket/894#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
