[geos-devel] [GEOS] #860: Prefer empty to size of zero
geos-trac at osgeo.org
Mon Mar 19 10:56:19 PDT 2018
Reporter: goatbar | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.6.3
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by goatbar):
And there are some easy to find instances of the same thing:
find . -name \*.cpp | xargs egrep '[.]size()' | egrep '== *0|0 *=='
./geomgraph/EdgeEndStar.cpp: if (edgeMap.size()==0) return nullCoord;
./geomgraph/EdgeEndStar.cpp: if (edgeMap.size()==0) return true;
./operation/buffer/SubgraphDepthLocater.cpp: if
(stabbedSegments.size()==0) return 0;
./operation/overlay/LineBuilder.cpp: if ( v3d.size() == 0 )
./linearref/ExtractLineByLocation.cpp: if (newCoordinateArray.size() ==
0)
Ticket URL: <https://trac.osgeo.org/geos/ticket/860#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
