[geos-devel] [GEOS] #864: GEOSNode throws std::exception in PostGIS
GEOS geos-trac at osgeo.org
Fri Mar 30 12:10:26 PDT 2018
 Reporter:  komzpa      |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.6.3
Component:  Default     |    Version:  3.6.2
 Severity:  Unassigned  |   Keywords:
 [local] gis at gis=# select
 ST_Node(ST_GeomFromWKB('\001\002\000\000\000\011\000\000\000b\020X9
 }\366 at 7\211A\340\235I\034A\316\326t18}\366@\306g\347\323\230I\034Ay\351&18}\366@\331\316\367\323\230I\034A\372~j\274\370}\366@\315\314\314LpI\034A\343\245\233\304R}\366 at R\270\036\005?I\034A\315\314\314\314Z~\366@\343\245\233\304\007I\034A\004V\016-\242}\366@\252\361\322M\323H\034A\351&1\010\306{\366 at H\341z\0247I\034Ab\020X9
 }\366 at 7\211A\340\235I\034A'));
 ERROR:  XX000: GEOSNode: std::exception
 Time: 1,215 ms
Ticket URL: <https://trac.osgeo.org/geos/ticket/864>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
