[geos-devel] [GEOS] #874: Memory leaks in GEOSSTRTree_nearest
geos-trac at osgeo.org
Thu May 31 01:19:49 PDT 2018
Reporter: dbaston | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.6.3
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
See if it is appropriate to use getEnvelope_internal instead,
which gets a link to the internal (Geometry-owned) envelope.
Ticket URL: <https://trac.osgeo.org/geos/ticket/874#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
