[geos-devel] Possible speed improvement for overlay operations
Paul van der Linden
paul.doskabouter at gmail.com
Fri Nov 30 13:13:13 PST 2018
Well, the part I'm referring to is the 1. and 2 (Compute self-intersection
nodes for A and B) as far as I understand.
Traced through from
https://github.com/libgeos/geos/blob/8bc1ea0f8019bcb83c60126e7883ae428ea7c677/src/geomgraph/GeometryGraph.cpp#L393
to
https://github.com/libgeos/geos/blob/8bc1ea0f8019bcb83c60126e7883ae428ea7c677/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp#L55
to
https://github.com/libgeos/geos/blob/8bc1ea0f8019bcb83c60126e7883ae428ea7c677/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp#L126
Increased a counter here
SimpleMCSweepLineIntersector.cpp#L161 and put a breakpoint here
https://github.com/libgeos/geos/blob/8bc1ea0f8019bcb83c60126e7883ae428ea7c677/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp#L166
counter's value at the end of the computeintersections was n*n, and
breakpoint never hit, so a lot of checks were done without any useful work.
Not really sure how "representative" my polygons are, but they are squares
with zig-zag boundaries
don't know if that will come out right, but here's the snippet I used to
check this:
Geometry* getlargeGeo(double x, double y)
int i;
const int n = 1000;
GeometryFactory::Ptr factory = GeometryFactory::create();
CoordinateSequence* coords =
factory->getCoordinateSequenceFactory()->create((size_t)0);
for (i = 0; i < n; i++)
coords->add(Coordinate(x + i * 10, y + (i % 2) * 3));
Coordinate last = coords->getAt(coords->size() - 1);
coords->add(Coordinate(last.x + (i % 2) * 3, last.y + i * 10));
coords->add(Coordinate(last.x - i * 10, last.y + (i % 2) * 3));
coords->add(Coordinate(last.x + (i % 2) * 3, last.y - i * 10));
coords->add(coords->getAt(0));
LinearRing *shell = factory->createLinearRing(coords);
return factory->createPolygon(shell, NULL);
Geometry* lg1 = getlargeGeo(0, 0);
Geometry* lg2 = getlargeGeo(100, 50);
Geometry* res3 = lg1->intersection(lg2);
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20181130/4fe3de76/attachment.html>
