[geos-devel] RFC7 - Use CMake as build system for GEOS
Sandro Santilli
strk at kbt.io
Thu Oct 4 01:50:34 PDT 2018
On Wed, Oct 03, 2018 at 02:41:34PM -0400, Daniel Baston wrote:
> Are you asking whether the GEOS test suite can be run against
> a non-installed copy of the library (yes), or are you referring to
> other tests?
I'm asking if we can have a "make check" rule, generated by CMake,
that will run the same tests run by current "make check" rule
generated by autotools and with the same important condition of
built binaries and libraries _NOT_ moving out of the build tree.
Also I'd like to have a "make dist" and "make distcheck" and
of course the other custom ones ("apidoc"/"doxygen"/"pdf",
"gen-ChangeLog" etc.)
--strk;
