[geos-devel] RFC7 - Use CMake as build system for GEOS
    Daniel Baston
    dbaston at gmail.com
    Thu Oct  4 06:39:11 PDT 2018
> What you can do to make _me_ use cmake is providing the
> UI and functionality I'm used to
The pieces I'm not sure about are "make dist" and "make distcheck."
The other things you listed are supported. I can try and clarify the docs
at https://trac.osgeo.org/geos/wiki/BuildingOnUnixWithCMake
> If you can get CMake to reach that state of functionality
> I might start using it and see how hard it would be for me
> as a contributor to also maintain it.
I think it's at a state where you could try it for development.
Dan
