[geos-devel] [GEOS] #931: Add "dist" and "distcheck" targets to CMake
geos-trac at osgeo.org
Thu Oct 4 06:51:43 PDT 2018
Reporter: dbaston | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.6.2
Severity: Unassigned | Keywords:
From Bas Couwenberg:
autotools and cmake take the opposite approach to creating
distribution
archives.
autotools only includes the files it is configured to.
cmake includes everything in the source tree not explicitly
excluded.
To support `make dist` with CMake you need to add a custom
target:
add_custom_target(dist COMMAND ${CMAKE_MAKE_PROGRAM} package_source)
And configure CPACK_SOURCE_IGNORE_FILES to exclude everything that
should not end up in the archives.
For `make distcheck` you'll need to implement more custom targets.
NetCDF may be a source of inspiration:
https://github.com/Unidata/netcdf-c/blob/master/cmake/modules/FindMakeDist.cmake
Ticket URL: <https://trac.osgeo.org/geos/ticket/931>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
