[geos-devel] RFC7 - Use CMake as build system for GEOS
Sandro Santilli
strk at kbt.io
Thu Oct 4 07:16:28 PDT 2018
On Wed, Oct 03, 2018 at 10:39:35PM -0400, Regina Obe wrote:
> But for me even when autotools WAS working GEOS compiled way faster
> under CMake than it did under autotools.
I got curious and tested on my system (Ubuntu GNU/Linux 18.04.1 LTS).
For me, autotools build is slightly faster:
build-autotools$ time ( ../configure && make; )
real 5m53.185s
user 5m27.561s
sys 0m27.071s
build-cmake$ time ( cmake ../ && make; )
real 6m18.942s
user 5m47.012s
sys 0m31.433s
Versions:
cmake version 3.10.2
automake (GNU automake) 1.15.1
autoconf (GNU Autoconf) 2.69
libtool (GNU libtool) 2.4.6
Install/uninstall steps:
build-cmake$ time sudo make install
real 0m1.514s
user 0m0.403s
sys 0m0.232s
build-cmake$ time sudo make uninstall
real 0m3.160s
user 0m2.130s
sys 0m1.048s
build-autotools$ time sudo make install
real 0m10.302s
user 0m9.643s
sys 0m0.737s
build-autotools$ time sudo make uninstall
real 0m0.802s
user 0m0.732s
sys 0m0.109s
Note that the extra time on "make install" for autotools
is due to some problematic dependency encoded to deal with
GEOS revision flag, used to build final library (not sure
a ticket exists for that already)
--strk;
