[geos-devel] [GEOS] #932: improve static-library build
GEOS geos-trac at osgeo.org
Fri Oct 5 06:42:24 PDT 2018
 Reporter:  basiliscos  |      Owner:  geos-devel@…
     Type:  patch       |     Status:  new
 Priority:  major       |  Milestone:
Component:  Default     |    Version:  master
 Severity:  Unassigned  |   Keywords:
 When I launch CMake with the following parameters:
 cmake -DGEOS_BUILD_STATIC=on -DGEOS_BUILD_SHARED=off ..
 it fails with the error:
 CMake Error at capi/CMakeLists.txt:45 (add_dependencies):
   Cannot add target-level dependencies to non-existent target "geos_c".
   The add_dependencies works for top-level logical targets created by the
   add_executable, add_library, or add_custom_target commands.  If you want
 to
   add file-level dependencies see the DEPENDS option of the
 add_custom_target
   and add_custom_command commands.
 The provided patch makes it optional to build C API (on by default, as in
 master), and static library builds fine.
 The geos version is 3.7.0
Ticket URL: <https://trac.osgeo.org/geos/ticket/932>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
