[geos-devel] [GEOS] #932: improve static-library build
geos-trac at osgeo.org
Fri Oct 5 06:44:31 PDT 2018
Reporter: basiliscos | Owner: geos-devel@…
Type: patch | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by basiliscos):
With the patch it is possible to configure CMake as
cmake -DGEOS_BUILD_STATIC=on -DGEOS_BUILD_SHARED=off -DGEOS_BUILD_CAPI=off
Ticket URL: <https://trac.osgeo.org/geos/ticket/932#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
