[geos-devel] C++ version, documentation and --std flags
Greg Troxel gdt at lexort.com
Sat Oct 6 12:57:43 PDT 2018
"Regina Obe" <lr at pcorp.us> writes:
> What error are you getting?  When I try to build using autotools, it also fails too building the tests
> https://trac.osgeo.org/geos/ticket/913
> I assume your issue is different as on mine looks like it's just
> looking for a non-existent file on my system And also mixing C and C++
> constructions (like namespace)
My error is different.
The problem seems to be that libgeos.la does not specify -lstdc++ as a
dependency_lib, and the capi test is linked with cc, not c++, so that
standard C++ library isn't linked.
Changing to using c++ instead of cc on that test makes it link, but I'm
not clear on what's right.
A basic question is if we expect linking with the geos C library to be
doable in an invocation of the C compiler (as linker) that does not
include -lstdc++.  I would think so, but I need to look further into how
this is supposed to work.
