[geos-devel] [GEOS] #933: Update Readme for 3.7 and master to note that C++11 is required
GEOS geos-trac at osgeo.org
Sun Oct 7 16:26:07 PDT 2018
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.7.1
Component:  Default     |     Version:  3.6.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by dbaston):
 The branch is called 3.7 instead of svn-3.7. Master has 3.8.0dev in
 CMakeLists.txt and configure.ac.
Ticket URL: <https://trac.osgeo.org/geos/ticket/933#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
